Trying to run pdagent on Nagios server running RHEL 9 system
Hi, I have installed the pdagent packages on a RHEL 9 system running Nagios. When attempting to run the agent /usr/share/pdagent-integrations/bin/pd-nagios. I get the following error:
Traceback (most recent call last):
File “/usr/share/pdagent-integrations/bin/pd-nagios”, line 188, in
import pdagent.config
ModuleNotFoundError: No module named ‘pdagent’
During handling of the above exception, another exception occurred:
File “/usr/share/pdagent-integrations/bin/pd-nagios”, line 194, in
My system is running python3:
Python 3.9.18 (main, Jan 4 2024, 00:00:00)
[GCC 11.4.1 20230605 (Red Hat 11.4.1-2)] on linux
within python when I list the modules i see that pdagent and pdagentd are present.
The following packages were installed:
pdagent-1.7.4-1.noarch
pdagent-integrations-1.6.2-1.noarch
Any ideas folks?
Hi @chris.hardy
We recently rotated our TLS certificates, and while that usually doesn’t cause any issues, this year some folks are having trouble with the pdagent tools related to the rotation. Our CA has a new root certificate that isn’t in some bundles.
On RHEL, you should be able to update the ca-certificate package to see if that is contributing to what’s going on with pdagent.
